Date/Time: Wed, 08 Jan 2025 17:57:24 +0000
Spreadsheet system/Alert
View Count: 701
[2016-07-14 17:32:15] |
User578759 - Posts: 4 |
I am using the Spreadsheet system/alert study in a chartbook consisting of 5 other charts. The SSA is attached to a particular chart. If I want to create another SSA for one of the other charts in the chartbook, will I encounter problems with the logic in either of the SSAs, as they are both in the same chartbook? I thought I read in your documentation that this wasn't advised for the Spreadsheet System for Trading, and that's the basis for my question with the Spreadsheet system/alert. email is mallen314@gmail.com |
[2016-07-14 18:16:45] |
There is no problem with this. will I encounter problems with the logic in either of the SSAs, as they are both in the same chartbook?
