Date/Time: Wed, 08 Jan 2025 17:48:11 +0000
Unhide All Studies
View Count: 750
[2016-07-14 16:19:32] |
6c7574686572 - Posts: 20 |
Is it possible that this new feature set would save the state of the current studies of a chart instead of hiding and unhiding ALL studies? For example, the chart has 10 studies, 2 of them are hidden, 8 are visible. Hide All Studies hides everything. Unhide All Studies then unhides ALL 10 studies - an undesirable result in my opinion. Thank you. |
[2016-07-14 16:59:24] |
This is not supported and is not planned.
