Date/Time: Wed, 08 Jan 2025 18:03:37 +0000
quote page
View Count: 742
[2016-07-14 04:46:12] |
User28682 - Posts: 233 |
Hi, I went to "New Quote Spreadsheet" and opened a new page and inserted a few symbols successfully. I didnt like all of the columns and tried deleting a column by highlighting an entire column,and clicking on delete column. It wouldnt disappear. Any idea on hot to customize this sheet and get rid of things? Thanks Tom |
quotes.png / V - Attached On 2016-07-14 04:45:35 UTC - Size: 33.71 KB - 220 views |
[2016-07-14 06:35:19] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GettingQuotes.html#QuoteSpreadsheetSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
