Date/Time: Wed, 08 Jan 2025 17:57:28 +0000
Chart DOM - how to Autocenter
View Count: 1775
[2016-07-14 01:08:22] |
User360283 - Posts: 506 |
I would like the Chart DOM to auto center within a fixed range on my volume chart. I have set the Chart DOM scale range to Constant Range. I have the Chart DOM set to Interactive scale Move. I have the range (ES) set a 2 ticks so the full Chart DOM from the Ask percent to the Bid percent is visible in the screen space. But, I must keep manually moving the Chart DOM to keep it fully in view. How can I set the Chart DOM to auto center within this range? |
[2016-07-14 05:57:01] |
You need to set the Constant Range Scale Mode setting. This is documented on this page: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html Once this setting is set correctly, then it is recommended to Reset the chart scale, which is also documented on that page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-14 05:57:28
