Date/Time: Wed, 08 Jan 2025 18:14:00 +0000
DeleteACSChartDrawing fails (returns zero)
View Count: 735
[2016-07-14 00:50:02] |
onnb - Posts: 662 |
The following call call to DeleteACSChartDrawing returns zero and drawing objects are not deleted. It does not do this in the past. What could cause it to return zero? In what cases does this method fail to delete drawing objects? int ret = sc.DeleteACSChartDrawing(0, TOOL_DELETE_ALL, 0); if (ret == 0) { sc.AddMessageToLog("Error deleting all drawings", 0); } Date Time Of Last Edit: 2016-07-14 00:50:28
[2016-07-14 23:18:12] |
We are checking on this.
[2016-07-15 00:37:04] |
This should be working properly in the latest release.
