Date/Time: Wed, 08 Jan 2025 17:54:50 +0000
Data Feed from Google Finance
View Count: 4137
[2016-07-13 05:37:38]
User763472 - Posts: 22
Dear Sir,
I need to get the intraday chart for CSI 300 Index (Google Symbol: SHA:000300 -> Converted Symbol: 000300-SHA), which is unfortunately not included in IB.
Google Finance has it and I opened a separate Sierra Chart session to get data from Google Finance. However I find out that it cannot even show historical chart for MSFT-NASDAQ.
Could you please let me know what went wrong? Please find the screen cut and message log below:
Google Financial Data | Connected to data server. | 2016-07-13 13:23:52
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-07-13 13:23:53
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-07-13 13:23:53
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-07-13 13:23:53
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-07-13 13:23:53
Google Financial Data | Using primary service for historical data for MSFT-NASDAQ | 2016-07-13 13:24:03
MSFT-NASDAQ Daily #4 | Reloading chart. | 2016-07-13 13:24:03
MSFT-NASDAQ Daily #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\MSFT-NASDAQ.dly | 2016-07-13 13:24:03
Google Financial Data | Using primary service for historical data for 000300-SHA | 2016-07-13 13:24:03
000300-SHA Daily #5 | Reloading chart. | 2016-07-13 13:24:03
000300-SHA Daily #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\000300-SHA.dly | 2016-07-13 13:24:03
MSFT-NASDAQ Daily #1 | Reloading chart. | 2016-07-13 13:24:03
MSFT-NASDAQ Daily #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\MSFT-NASDAQ.dly | 2016-07-13 13:24:03
Google Financial Data | Using primary service for historical data for MSFT-NASDAQ | 2016-07-13 13:24:04
Google Financial Data | Starting real-time market data updates for: MSFT-NASDAQ. ID: 1 | 2016-07-13 13:24:04
Google Financial Data | Requesting security definition data for: MSFT-NASDAQ. ID: 1 | 2016-07-13 13:24:04
HD Request # 2 | Downloading Historical Daily chart data for MSFT-NASDAQ. Starting date: 1966-07-13. Service: goog | 2016-07-13 13:24:04
Caught an unhandled exception in AsyncWindowProc. Message: 32795, wParam: 0, lParam: 0 | 2016-07-13 13:24:04 *
Google Financial Data | Using primary service for historical data for 000300-SHA | 2016-07-13 13:24:04
Google Financial Data | Starting real-time market data updates for: 000300-SHA. ID: 2 | 2016-07-13 13:24:04
Google Financial Data | Requesting security definition data for: 000300-SHA. ID: 2 | 2016-07-13 13:24:04
Historical Daily data request for MSFT-NASDAQ is discarded because a matching download is in progress and the new one is not for earlier data. | 2016-07-13 13:24:04
HD Request # 2 | Error downloading historical Daily data for MSFT-NASDAQ. The download timed out. | 2016-07-13 13:25:04
HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MSFT-NASDAQ | 2016-07-13 13:25:04
HD Request # 2 | Daily download COMPLETE for MSFT-NASDAQ. Completion time: 1m. Unique request ID: 1 | 2016-07-13 13:25:04
Removed historical data download ID 1 | 2016-07-13 13:25:04
HD Request # 3 | Downloading Historical Daily chart data for 000300-SHA. Starting date: 1966-07-13. Service: goog | 2016-07-13 13:25:04
Caught an unhandled exception in AsyncWindowProc. Message: 32795, wParam: 0, lParam: 0 | 2016-07-13 13:25:04 *
Google Financial Data | Using primary service for historical data for MSFT-NASDAQ | 2016-07-13 13:25:04
MSFT-NASDAQ Daily #4 | Reloading chart. | 2016-07-13 13:25:04
MSFT-NASDAQ Daily #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\MSFT-NASDAQ.dly | 2016-07-13 13:25:04
HD Request # 3 | Error downloading historical Daily data for 000300-SHA. The download timed out. | 2016-07-13 13:26:04
HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 000300-SHA | 2016-07-13 13:26:04
HD Request # 3 | Daily download COMPLETE for 000300-SHA. Completion time: 1m. Unique request ID: 2 | 2016-07-13 13:26:04
Removed historical data download ID 2 | 2016-07-13 13:26:04
Google Financial Data | Using primary service for historical data for 000300-SHA | 2016-07-13 13:26:04
000300-SHA Daily #5 | Reloading chart. | 2016-07-13 13:26:04
000300-SHA Daily #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\000300-SHA.dly | 2016-07-13 13:26:04
imageSierra Chart Google Finance.png / V - Attached On 2016-07-13 05:35:18 UTC - Size: 22.97 KB - 638 views
[2016-07-13 05:48:53]
We are fixing this problem now.
It will be solved in version 1444.
[2016-07-13 06:01:35]
Thanks very much!
FYI, I am trying the pre-release version (1444) now and it still cannot display the chart.
I look forward to your new release.
[2016-07-13 06:12:19]
Update to prerelease 1444 again following these instructions:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
It is the second revision of 1444 which resolves the problem.
