Date/Time: Wed, 08 Jan 2025 17:41:48 +0000
Deffrent data whan using "NUMBERS BARS" studies
View Count: 867
[2016-07-12 14:17:07]
User145792 - Posts: 22
Hi , I compered between the data shown in a standerd bar with the one of "Numbers bars" and it is not the same. For exm. If you try to look for a doji , using the "candelstick pattern finders" you will notice that the result are not the same
[2016-07-12 16:54:16]
Provide Chart images showing us what you mean. Here are instructions:
Date Time Of Last Edit: 2016-07-12 16:54:27
[2016-07-17 07:13:56]
http://www.sierrachart.com/image.php?Image=1468739534763.png
http://www.sierrachart.com/image.php?Image=1468739611528.png
[2016-07-17 09:01:52]
We see the chart images but describe very specifically what the difference is between one of the chart bars between these two charts.
Also, what is the timeframe of the chart bars in these charts. We cannot tell because you did not follow these instructions completely:
So at this point, we cannot help you.
Date Time Of Last Edit: 2016-07-17 09:02:02
[2016-07-17 13:22:00]
this is one min chart.
Anyway, if i look at NQUL 1 MIN. (new pic attached)
in standared veiw i see price change in bar of 0.38 whule it should be a Doji , and whan i look in it in numbers bars veiw the price change is 1.5?
could you please explain this?
imagedoji1.png / V - Attached On 2016-07-17 13:21:15 UTC - Size: 31.33 KB - 285 views
imagedoji2.png / V - Attached On 2016-07-17 13:21:28 UTC - Size: 64.68 KB - 277 views
[2016-07-18 01:51:58]
Go to the Numbers Bars chart that you posted an image of. Select Chart >> Duplicate Chart.
On that duplicated chart, remove all of the Studies on the chart through Analysis >> Studies.
You should notice that the bars are now identical.
If so, there is a difference in Chart >> Chart Settings between the charts.
Date Time Of Last Edit: 2016-07-18 01:56:59
