Date/Time: Sun, 24 Nov 2024 18:37:44 +0000
How to draw a vertical line at 3rd friday every month?
View Count: 1839
[2016-07-11 15:47:15] |
BrMa - Posts: 80 |
Dear ladies and gentlemen, I'm looking for a way to mark the 3rd friday of a month in a chart with daily bars to mark the expiration of options of the underlying. The vertical grid does not seem to help me because I wouldn't like to have a vertical line e.g. every 21 days but really every 3rd friday. And I could not find any study helping me doing this. Can you please help me out? Thanks a lot in advance! Regards, Markus |
[2016-07-11 16:33:01] |
There is no study available which does this.
[2016-07-11 16:35:35] |
We could add a study that will draw line at the specified Date but it would have to be a specific date and not something like the third Friday.
[2016-07-11 16:38:22] |
BrMa - Posts: 80 |
First of all, thank you very much for your fast reply! Can I implement this functionality programming it in ACSIL? Just to be sure not to use my time for something impossible... ;-) Regards, Markus |
[2016-07-11 17:07:44] |
Yes you can but it is easy enough for us to add. It would really be best for us to add this.
[2016-07-11 18:19:57] |
Sawtooth - Posts: 4119 |
You can do it with the Color Bar Based On Alert Condition study using this formula: =BARDATE=(DATE(YEAR(BARDATE),MONTH(BARDATE),1+7*3)-WEEKDAY(DATE(YEAR(BARDATE),MONTH(BARDATE),8-6))) Date Time Of Last Edit: 2016-07-11 19:02:05
[2016-07-12 06:30:09] |
BrMa - Posts: 80 |
Looks good! THANK YOU! :-) Regards, Markus |
[2016-07-12 12:32:10] |
If you'd rather have a vertical line, instead use the Color Background Based On Alert Condition study, with 'Use Vertical Line...' set to Yes.
[2016-07-12 13:16:01] |
BrMa - Posts: 80 |
Dear togilb, great hint - thank you! :-) Regards, Markus |
[2022-04-20 12:32:12] |
user_xyz - Posts: 416 |
Tom - thanks for your contributions! I've been using this alert to mark OPEX dates for some time and just realized this month OPEX 4/15 isn't printing, thoughts? |
[2022-04-20 15:50:49] |
4/15 was a market holiday (Good Friday), so there was no Daily bar, hence no alert.For this special situation, use this formula instead: =IF(BARDATE=DATE(2022,4,14),1,BARDATE=(DATE(YEAR(BARDATE),MONTH(BARDATE),1+7*3)-WEEKDAY(DATE(YEAR(BARDATE),MONTH(BARDATE),8-6)))) This will mark the Thursday 4/14/2022 bar, plus the 3rd Fridays of other months. Date Time Of Last Edit: 2022-04-20 19:36:17
[2022-05-04 20:48:29] |
Tom one more question if we wanted to mark quarterly OPEX cycles? Pls and thank you!
[2022-05-04 22:43:15] |
So you want to mark the last day of these months: Mar, Jun, Sep, Dec?
[2022-05-04 22:49:18] |
Yes. I'm assuming creating a new alert Color Background Based On Alert Condition for quarterly dates and change the order to display on top? Or if there is a way to add to existing keeping it all in one alert might be cleaner. I've found sometimes the easiest way (but creates clutter) is to just have multiple alerts.
Date Time Of Last Edit: 2022-05-04 22:50:35
[2022-05-05 03:32:21] |
I would use another instance of the color background study. This formula will work for 2022: =OR( BARDATE=WORKDAY(EOMONTH(DATE(2022,3,1),0)+1,-1), BARDATE=WORKDAY(EOMONTH(DATE(2022,6,1),0)+1,-1), BARDATE=WORKDAY(EOMONTH(DATE(2022,9,1),0)+1,-1), BARDATE=WORKDAY(EOMONTH(DATE(2022,12,1),0)+1,-1)) You'll need to edit the dates as needed. |
