Date/Time: Tue, 22 Apr 2025 21:02:29 +0000
Adjusting all Support/Resistance zones after rollover
View Count: 2754
[2016-07-09 13:08:24] |
EurexTrader - Posts: 8 |
Is there a way to shift all the S/R zones on your charts automatically after a futures contract has rolled over? I am new to SC and migrated over from Market Delta. MD has a neat function that adjusts all your S/R lines or zones (I am drawing them in SC using the horizontal rectangle function) by any specified amount which would save time manually shifting all these zones by hand. I have years worth of Support/Resistance zones on all the charts I trade off and after each rollover, it is important for me to carry these zones over from the old contract with a quick adjustment as having to do them manually would take up waaay too much time and is so far the only "dealbreaker" for me vis-à-vis the migration over from Market Delta. Thanks |
[2016-07-09 15:11:22] |
jackw - Posts: 57 |
You can adjust all the drawings on a chart at once. CTRL-ALT-M to open the Manage Chart Drawings Window. You can click on the futures contract header to select all drawings for that contract. Or, click on the drawing you want to move (CTRL-click to select multiple drawings, or CTRL-SHIFT-click to select a range of drawings). Then click on the Adjust button, enter the amount of the adjustment and click OK. |
[2016-07-09 22:05:32] |
Follow through the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_ChangingFuturesContract.html#AdjustingDrawingsMatchRollover Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-12 11:35:50] |
Wow thanks. Highly impressed with the support here!
