Date/Time: Fri, 10 Jan 2025 22:52:08 +0000
Tile as grid 2x3
View Count: 1495
[2016-07-08 09:46:57] |
User457299 - Posts: 38 |
Is it possible to arrange the chart layout to be 2x3 for the tile as grid? Currently when I tile as grid for my 6 charts within a same chartbook, it always gives me 3x2. Thanks. |
[2016-07-08 17:30:40] |
We will add an option to control this.
[2016-07-12 02:55:40] |
I have update my SC to 1441, but I do not see that there is a new tile function. Thanks. |
[2016-07-12 03:39:31] |
This is not yet available.
[2016-07-13 05:09:37] |
Ulaju - Posts: 56 |
"Tile Vertically" used to give me that result (2x3 grid). Now however it tiles them vertically from the top to the bottom which I find useless. I think this changed in the last update. I have all my chartbooks in 2x3 grid. Can we please get this function back? |
[2016-07-13 05:49:43] |
Yes. We are still working on this. Just allow about another week.
[2016-08-17 05:54:50] |
Ulaju - Posts: 56 |
Any news about this? =)
[2016-08-17 06:12:18] |
Have a look at the two Window >> Tile as Grid commands in the latest version. This is all that we can provide now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-18 11:04:49] |
Ulaju - Posts: 56 |
Can you please add the option to order the charts like it was before? number 1: corner top-left number 2: corner bottom-left number 3: middle-top number 4: middle-bottom etc... Because I organized my 40+ chartbooks that way and now it's all quite messy. Or maybe you can leave the default option to be like that? I honestly find it better and more intuitive. Generally speaking, if one trader is thinking about splitting the screen in two (for time charts and range charts, for example) he's gonna tend to put the charts of one type by the left and the charts of the other type by the right, instead of dividing between top and bottom. |
[2016-08-18 18:10:58] |
We will probably need to add an option for this because other users may have a different preference.
[2016-08-19 06:33:59] |
Ulaju - Posts: 56 |
I'm going to Philippines next week where I will have a different second screen resolution and this option would save me a huge amount of time rearranging everything... I would greatly appreciate if you can do it soon ^_^
[2016-10-17 13:13:19] |
Ulaju - Posts: 56 |
[2016-10-17 18:25:38] |
We do remember adding another tiling option. The available Tiling functions are documented here: http://www.sierrachart.com/index.php?page=doc/WindowMenu.html#TileAsGridHorizontally Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
