Date/Time: Tue, 07 Jan 2025 20:49:01 +0000
Automatic Line Draw at Open Close
View Count: 1011
[2016-07-07 01:58:30] |
toews&kane - Posts: 209 |
Hi there, Is there a function that will draw a horizontal line and project it a certain length, and at a certain point in time automatically, say at open and close? Cheers |
[2016-07-07 03:47:59] |
Yes. Use the Horizontal Line at Time study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s306 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
