Date/Time: Tue, 07 Jan 2025 20:53:00 +0000
CQG Connection
View Count: 606
[2016-07-06 19:25:04] |
User513662 - Posts: 90 |
Hi, I read through the CQG connection guide and it mentions a list of brokers required. The broker I am considering that offers CQG is not listed there (Macquarie Futures). Does this matter or do I simply need to let them know that I'll be using Sierra Chart? |
[2016-07-06 19:35:21] |
It does not matter. You can use any broker. But you do need to let them know you will be using Sierra Chart.
[2016-07-06 19:40:01] |
Thank you.
