Date/Time: Wed, 16 Sep 2026 22:27:14 +0000
[Programming Help] - Questions on creating a ratio study
View Count: 979
[2016-07-06 19:04:53]
User702211 - Posts: 6
Hi
I am trying to create a Ratio study: X variable / Y variable.
However, both of X variable and Y variable will possibly change its signs to be positive or negative in real time.
These will cause the Ratio becomes unstable, moving from one extreme to another extreme (e.g. from +ve zone to -ve zone in 1 bar.)
I would like to add a constant to X-variables to solve it. Does Sierra Chart supports ?
Or is there any tools or studies in Sierra Chart are able to handle such situations?
Thank you very much for your advice and help!
Date Time Of Last Edit: 2016-07-06 19:32:46
[2016-07-07 11:38:31]
jackw - Posts: 57
You can use the 'Study Subgraph Add' study to add a constant to your X variable. You can hide the study if you don't want the result to be displayed.
Then use the 'Study Subgraphs Ratio' to calculate the ratio between your Y variable and the adjusted X Variable.
Note: Don't get the 'Study Subgraph...' and the 'Study Subgraphs...' studies confused with each other.
