Date/Time: Tue, 07 Jan 2025 20:44:45 +0000
bring to front
View Count: 1031
[2016-07-06 18:53:02] |
User771416 - Posts: 47 |
my price bars are sitting on top of my profile and i cant really see the profile. is there a way to "bring to front", or send to back for the bars?
[2016-07-06 19:00:47] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#StudyDisplayOrder Make sure you are using the latest prerelease of Sierra Chart for the latest changes in regards to this. Refer to: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-06 19:16:35] |
Thanks for the reply, the update solved it.
