Date/Time: Tue, 07 Jan 2025 20:22:05 +0000
SC on Windows 11
View Count: 962
[2016-07-06 16:23:47] |
Willson - Posts: 176 |
Since the free version of Windows 11 expires 7/29/ 2016 I was hoping to switch to the new version. But I see in SC Requirements that it is not supported, ie Support is listed thru Windows 10. Is this a firm rejection of Win 11? or will it work anyway? I use Windows 7, but I don't want to skip the free update on several computers unless necessary. Guidance appreciated. Thanks |
[2016-07-06 17:35:42] |
We are not aware that there is a Windows 11. However, whatever Microsoft operating system is available and is meant to update a previous one, then it is supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-06 19:32:02] |
Sorry, It is Win 10 that has the July update limit. Got confused again.
