Date/Time: Tue, 07 Jan 2025 20:34:04 +0000
3 questions
View Count: 960
[2016-07-06 07:09:30] |
User347737 - Posts: 9 |
I have 3 things that I am struggling with if I could get some help: If I put the bund, for example, on GG# for a rolling daily chart I stop getting a live feed. It seems to drop into a historical only mode. That means the only way to get a "live" daily chart is to have it on GGU16 and then I need another chart for historical. Is there a way to combine the 2 and have GG# live? 2. How do I get a weekly Market Profile up? 3. How do I get a pit only session for the spoo (ES#) on a daily chart? Thanks Dan |
[2016-07-06 08:57:38] |
1. You need to use the Continuous Futures Contract feature: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Do not use the # in a symbol. It is not reliable. 2. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html 3. Once again do not use the # in a symbol. The use of this should not be documented anywhere. Follow these instructions: https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php#DaySessionOnlyDaily Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-06 13:40:37] |
I have resolved the continuous setting so many thanks. I am struggling with pit only still and weekly charts. Cant get it. Any further help??
[2016-07-06 17:30:31] |
For the instructions to create Daily chart bars that consist of the day session only, this is documented clearly step-by-step here: https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php#DaySessionOnlyDaily When you say market profile do you mean TPO profile charts? Or do you mean Volume Profiles? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-07 06:16:27] |
both please
[2016-07-07 17:56:16] |
It is important to follow through the step-by-step instructions for the Volume by Price study: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php And the TPO profile chart study: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html To understand how they work. Once that is done, to set the Volume by Price study to weekly volume profiles requires changing these inputs: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#InputVolumeGraphPeriodType (set to Multiple Profiles Fixed by Time) https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#InputTimePeriodTypeForFixedTime (Set to Weeks) The setup instructions for the TPO Profile Chart study have been updated to explain how to do weekly TPO profiles. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-07 17:56:56
