Date/Time: Wed, 08 Jan 2025 17:43:13 +0000
How to set chart loading data automatically?
View Count: 1018
[2016-07-06 03:32:41]
User701247 - Posts: 117
I have subscribed package 5, and would like to know on how to set chart loading data automatically.
Furthermore, the time zone is different from my location and would like to know on how to adjust the time zone also.
Does anyone have any suggestions?
Thanks in advance for any suggestions
[2016-07-06 04:04:07]
To open Chartbooks automatically, refer to:
https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#AutomaticallyOpenChartbook
To change the time zone, refer to:
https://www.sierrachart.com/index.php?page=doc/doc_TimeZone.html
[2016-07-07 05:34:09]
Referring to following link, I cannot find any related information on how data would be automatically updating when opening a chart.
I have opened a chart, but the latest data is 17 Jun, 2016 at 21:29.
Furthermore, after defining all setting for study, I would like to set this setting as default, so whenever I open any chart, this study's setting would automatically apply for all charts.
DO you have any suggestions?
Thanks you very much for any suggestions
Date Time Of Last Edit: 2016-07-07 05:39:41
[2016-07-07 13:05:07]
What is the symbol of the chart that is not updating?
Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_StudyCollections.html#AutomaticallyApplying
[2016-07-10 02:41:14]
Symbol : ESM16 and the latest date is 17 Jun, 2016 at 21:29
Since I have edited the study for symbol ESM16 for my preference, when I open chart for symbol ESU16, how to apply those study's setting from ESM16 into ESU16? without setting everything from scratch.
On the other hands, I have IB account, do I need to setup Sierra Chart with my IB account information in order to access real-time data? If yes, how to do the setting?
Do you have any suggestions?
Date Time Of Last Edit: 2016-07-10 02:43:14
[2016-07-10 06:39:02]
You need to change the symbol of the chart to ESU16. Follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html#ChangingChartSymbol
To use the real-time data from your Interactive Brokers account, follow the instructions here:
Interactive Brokers Trading Service: Setup Instructions
[2016-07-10 11:50:11]
Please see attached image, I would like to know on how to change the font size, Number bar does not show properly.
Furthermore, I would like to reduce the height of the bottom information (black background color), so chart can be shown more data.
Date Time Of Last Edit: 2016-07-10 11:53:07
imageImage.JPG / V - Attached On 2016-07-10 11:49:20 UTC - Size: 342.15 KB - 272 views
[2016-07-11 09:21:27]
https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#Scaling
Refer to step 9 here:
https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#NumericInformationBelowBars
Date Time Of Last Edit: 2016-07-11 16:15:30
[2016-07-11 12:06:15]
The data is not automatically updated, I need to press Dis and then press Con in order to see the latest data.
I would like to know on what requirement is to load real-time data automatically, do I need to setup my IB account setting here?
[2016-07-11 16:29:06]
You need to connect to your Interactive Brokers account for real-time futures and stock data. Follow the instructions here:
[2016-07-13 02:59:19]
I successfully load real-time data, but I get the issue on fonts size,
For the image Font2.jpg, I open an original chartbook, the font size looks fine, but
For the image Font.jpg, I use the same chartbook and just change the symbol and save as another name, the font looks too small.
Furthermore, I would like to change the background color to be light grey.
Date Time Of Last Edit: 2016-07-13 03:31:19
imageFont.JPG / V - Attached On 2016-07-13 02:59:15 UTC - Size: 391.4 KB - 284 views
imageFont2.JPG / V - Attached On 2016-07-13 03:26:37 UTC - Size: 335.88 KB - 280 views
[2016-07-14 05:58:59]
We do not recommend using the Numbers Bars study on an Interactive Brokers cash Forex symbol. That is why it does not look correct and the numbers are overlapping and inaccurate.
Refer to this page for the related documentation for graphics related settings:
https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html
Date Time Of Last Edit: 2016-07-14 06:02:48
