Date/Time: Thu, 16 Jan 2025 16:13:52 +0000
Customize X-axis and Y-axis
View Count: 2598
[2016-07-05 20:41:08] |
User702211 - Posts: 6 |
Hi, I would like to customize the X-axis and Y-axis myself to study the relationship between X and Y variables. The X and Y variables are computed in two subgraph studies. May you please advise does Sierra Chart support this setting ? Thanks a lot. |
[2016-07-06 04:05:51] |
This can be done by creating a custom chart using ACSIL. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scIsCustomChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-08 10:01:07] |
User164231 - Posts: 278 |
Hi, When I set the 'X and Y axis Constant Relationship' the latest price is always at the middle of the price scale (see pic). How do I set the last price 'intelligently' position at the price scale to maximize view? Also, is it possible to configure the scroll of the mouse to move the X and Y axis once this setting (X and Y axis Constant Relationship) is selected? Basically I want it to function like TC2000 when I move around checking price action as I am used to such setting. Could you show me how to set it to mirror TC2000 when scrolling the chart? Thanks. Date Time Of Last Edit: 2017-11-08 11:29:41
Private File |
[2017-11-08 18:55:33] |
How do I set the last price 'intelligently' position at the price scale to maximize view? The best you can do is to use Interactive Scale Move:http://www.sierrachart.com/index.php?page=doc/Scaling.html#InteractiveScalingMoveUpDown Also, is it possible to configure the scroll of the mouse to move the X and Y axis once this setting (X and Y axis Constant Relationship) is selected? Here is documentation for scrolling the chart: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#ScrollingTheChart And documentation for changing the bar spacing: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#ChangingBarSpacing We cannot provide further help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-08 18:56:00
[2017-11-10 05:16:25] |
People. Found my solution to use mouse scrolling to control the zooming in and out. It is under Global Setting/General 2 at the last column.
