Date/Time: Tue, 07 Jan 2025 20:28:29 +0000
Date list Trans fill rect top/bottom
View Count: 660
[2016-07-05 17:56:25] |
User92573 - Posts: 538 |
Dear Support My apologies as I've made 2-3 requests that I'm sure are low-level in the list of your priorities. Can you tell me whether there is a built in study that will allow me to reference a 'date listing' (holidays etc) which then marks the chart with a rectangle from top to bottom? I'm just checking before programming as I didn't find anything when I ran a search but realize it may be described differently. Many thanks. |
[2016-07-05 23:03:44] |
No, this is not available.
