Date/Time: Wed, 08 Jan 2025 17:55:49 +0000
[Locked] - New Billing Method to be Released at the End of the Day on July 7
View Count: 3526
[2016-07-05 06:19:16] |
In this section here we document the new billing method to be released at the end of the day July 8: Sierra Chart Purchase and License Information: Renewing Access It could be delayed if there any technical problems. Discounts will be replaced with a single discount based upon the long-term user discount. Every month paid for will get an increasing discount. We are still working out the exact percentage though. Paying for a service package will always be made through your Services Balance. You can activate and deactivate the Service Package at anytime on your account. So this gives you the capability to put your account on hold if you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-15 04:11:17
[2016-07-06 05:15:31] |
We are delaying the release of this until July 6.
[2016-07-07 05:03:26] |
We are delaying the release of this until the end of the day July 7 or July 8. For the moment, we expect the discount per month to be 2%. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-07 05:03:51
[2016-07-15 04:12:17] |
The new billing and payment method has been released. For every month of usage time purchased, you receive a discount for the next month. This discount is 2 percent per month and increases up to 36 percent. It is recommended to keep a sufficient balance on the Services Balance for at least several months of usage time depending upon what you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-15 05:29:41
