Date/Time: Tue, 07 Jan 2025 20:57:57 +0000
Multiple Studies in same Chart region
View Count: 707
[2016-07-04 15:33:38] |
User92573 - Posts: 538 |
Dear Support, I'd be grateful if you would clarify whether this will create an issue in either the real-time or playback mode. I have 3 studies: 2 x ATR and 1 x Bar Difference; all are set to Draw Style Ignore, and all three are in Chart region 2. The "Text Display for Study" then allows me to place the 2 ATR values in the Main Graph. However, more importantly this allows me to see all 3 of the values together - in the Chart Values Tool Region 2. Am I causing a possible error, or any other issue, by bringing all three together in the same Chart region? Many thanks Paul Please note when I close the preview (Hide) I get an error. It may be my browser or possibly an SC page error. Just a heads up in case you'd like to check. Many thanks Paul. |
[2016-07-04 19:18:33] |
There is no problem with the study configuration. Please note when I close the preview (Hide) I get an error. It may be my browser or possibly an SC page error. Just a heads up in case you'd like to check.
We need to understand more precisely what you are doing. But this does sound like a browser problem.
