Date/Time: Tue, 07 Jan 2025 20:34:21 +0000
Every day the holes in the graph occur
View Count: 979
[2016-07-03 08:05:40]
User39949 - Posts: 25
Every day the holes in the graph occur. They begin at the time when I switch off the Platform and the End at two o´clock of Central European Time. The upgrade to the actual version of Sierrachart 1434 didn´t help. This problem has started three weeks ago. My datafeed is Rithmic. You can see it in the picture.
Date Time Of Last Edit: 2016-07-03 08:09:26
imageScreenshot - 30. 6. 2016 , 15_33_15.png / V - Attached On 2016-07-03 08:05:27 UTC - Size: 97.25 KB - 295 views
[2016-07-03 16:06:40]
Viacheslav Malafeev - Posts: 88
What about F5-Session Times?
[2016-07-03 19:10:49]
User27701 - Posts: 9
Session Times is right.You can see it in the picture:
imageScreenshot - 3. 7. 2016 , 21_06_31.png / V - Attached On 2016-07-03 19:10:46 UTC - Size: 39.67 KB - 296 views
[2016-07-03 22:17:33]
Follow through the step-by-step instructions to re-download the missing data:
https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#RetryDownloadDataInChart
Make sure you follow through all of the steps including updating the Symbol Settings.
And be sure to re-download all the data in the chart with Edit >> Delete All Data and Download.
