Date/Time: Sat, 18 May 2024 06:48:12 +0000
21 Day Price Channel
View Count: 1592
[2016-07-02 07:59:32] |
User289001 - Posts: 7 |
I am looking for a Price Channel study that i can apply to chart region 1 where my ohlc bars are being painted and i can't seem to find a price channel study can you help me... Thank you Raymond |
[2016-07-02 10:28:46] |
How exactly would the price channel be calculated?
[2016-07-03 18:06:17] |
i'm guessing here but what i'm looking for is a channel based upon each bars close i'll try to attach a picture to explain https://youtu.be/3gNxBYL1oJU?t=2483 Similar to a Bollinger Band... I know it's a study available on Think or Swim...
[2016-07-03 21:03:59] |
As a matter of policy we will not accept the video: Support Board Posting Information: Do Not Post Videos Unless Requested! Have a look at the following studies: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s14 https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s6 https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s26 https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s54 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-04 02:57:01] |
ok thank you for the suggestions i'll check them out...
[2016-07-04 03:29:43] |
The one study that most closely resembles the price channel that i was looking for is the Highest High/Lowest Low over N Bars... So i believe we have a winner if i have any further questions i'll contact you again thank you for your help...
[2016-07-28 20:18:05] |
User931593 - Posts: 28 |
You can use Donchian Channel. It is the same as price channel on Thinkorswim
