Date/Time: Tue, 07 Jan 2025 20:42:03 +0000
Number bars BID/ASK in percentage format
View Count: 1376
[2016-07-01 17:58:01] |
User560062 - Posts: 100 |
Hi, is there a way to have number bars in sierra to display bid/ask in percentage format coloured bars. Similar to the attachment below? |
bidask.PNG / V - Attached On 2016-07-01 17:57:03 UTC - Size: 2.11 KB - 290 views |
[2016-07-02 00:17:32] |
This is controlled by this Numbers Bars Input: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#BackgroundTypes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-02 10:07:24] |
well, of course I did go through all those settings before asking the question but I didn't find a way to display bid/ask next to each other with a percentage for the bid / ask volume. Is this possible or not? |
[2016-07-02 10:09:02] |
Do you mean actually display the calculated percentage?
