Date/Time: Wed, 08 Jan 2025 18:09:12 +0000
Pricing details for India (NSE Futures, Options , Stocks and indices) + Service package 5
View Count: 3932
[2016-07-01 15:35:08] |
SatyamB - Posts: 1 |
Hi , I am looking for the price of the following: Pricing details for 1. India (NSE Futures, Options , Stocks and indices) + 2. Service package 5 3. Intraday and EOD data Can you please let me how to get this pricing? Thanks, SatyamB |
[2016-07-01 19:01:34] |
Only end of day data is available for the NSE. Real-time and Intraday data hopefully will become available later through a broker in India which we may work with in regards to this. To access the historical end of day data, use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Here are the symbol lists: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=4#NSE https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Futures#nse For the cost of service package 5, refer to: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-01 19:02:52
[2016-07-19 12:01:29] |
User279714 - Posts: 21 |
Is the EOD data not adjusted with splits bonus etc.
[2016-07-19 17:35:27] |
There is a setting to control this. The setting for this is documented here: https://www.sierrachart.com/index.php?page=doc/doc_DataSourceSettings.php#DownloadDividendAdjustedHistoricalData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-20 00:51:20] |
I have already selected Download Dividend Adjusted Historical Data and please check with INFY.NS on 2015-06-15 it was split into 2 and i tried the option to delete all data and download but it is not adjusting . Please check into the same
[2016-07-20 01:41:09] |
We have contacted our data provider about this. You can manually adjust the data now by following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_AdjustingData.html#StockSplit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-20 15:42:14] |
If the Sierra chart is left open continuously will the eod data of NSE gets updated on the chart automatically everyday or do we need to reload everyday.
[2016-07-20 16:38:34] |
Yes it will get automatically updated.
