Date/Time: Tue, 07 Jan 2025 20:51:31 +0000
demo on SCs at the same time as trade live
View Count: 613
[2016-07-01 03:46:49] |
User78926 - Posts: 69 |
Hi there, I want to demo on SCs at the same time as trade live. Do I simply download a second SC platform? If so I assume I just copy the contents of the data folder across to the 'new' SC platform. Also where or how do I copy all my customised tool bar setup and password configuration across as this would save a lot of time? Thanks and regards, Mark |
[2016-07-01 07:31:56] |
User13668 - Posts: 294 |
@78926 See this thread where I asked the same question: Using SIM1 and Live account credentials at the sametime |
[2016-07-01 08:17:12] |
The easiest way to do this is to use File >> New Instance and set that new instance to use Trade Simulation Mode. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php#UsingDTCServerForDataAndTradingInAnotherSCInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
