Date/Time: Tue, 07 Jan 2025 20:30:12 +0000
Intraday Intensity/II%
View Count: 1475
[2016-07-01 02:31:45] |
chrysostom - Posts: 1 |
I looked in the helpfiles and all through the program itself (which is somewhat unintuitive) and can't find II/II%. What are they called in Sierrachart? I found user-submitted "Intraday Intensity Oscillators", I'm just looking for plain II and II%. The only thing that's keeping me from buying the program is the lack of this indicator. It would also be nice if you could invert p&f charts like in Updata, but Updata is $110/pcm. |
[2016-07-05 11:08:24] |
We do not know what II and II% is. So you can assume that Sierra Chart does not have it. It is possible to invert Point and Figure charts. Just use the Invert Prices setting: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#InvertPrices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
