Date/Time: Tue, 07 Jan 2025 20:44:25 +0000
Download of Intraday Monthly/Weekly/Daily Data seems limited in range
View Count: 719
[2016-06-30 21:12:19] |
User316362 - Posts: 210 |
I know I used to have a range of data much further back . It seems I'm limited to about 5 years now. I need about 8 years to draw proper monthly channels etc. And I really need intraday for trading hours only. Has something changed? Or what Am I doing incorrectly? ESU6 [CV] [M] 1 Month #2 | Reloading chart. | 2016-06-30 17:06:31 ESU6 [CV] [M] 1 Month #2 | Limiting the number of years to download historical data for to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2016-06-30 17:06:31 |
[2016-07-01 05:21:12] |
To overcome the single digit year limitation with TransAct, install another copy of Sierra Chart on your system and use the Sierra Chart Historical Data Service. Here is the complete documentation for this: Sierra Chart Historical Data Service You can then open the longer-term charts in that copy of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-02 13:11:27] |
If I were to create a separate instance for historical using the sierra data feed, will I be required to purchase another connection? That is, I'm using transact trading on current instance. I would use Sierra Hisotrical Data for second and run them both on the same computer at the same time. Date Time Of Last Edit: 2016-07-02 13:38:19
[2016-07-02 22:18:19] |
No you do not have to pay anything extra for this. If this were the case, we would have already indicated what that would be. I would use Sierra Hisotrical Data for second and run them both on the same computer at the same time.
Yes this is correct.
