Date/Time: Tue, 07 Jan 2025 20:35:29 +0000
Alert Manager, Message Log Pop up
View Count: 2080
[2016-06-30 15:02:08]
User341584 - Posts: 44
I have delta divergence indicator on a few charts. EVERY time an alert is triggered, the Alert Manger box pops up and the Message Log box pops up because I dont have a SMS number specified.
Can I disable these pop ups? Starting to get annoying. I don't even have SMS box checked.
Im including a couple pics to help verify my settings.
Any help is appreciated.
M
imageCapture1.PNG / V - Attached On 2016-06-30 15:01:57 UTC - Size: 79.27 KB - 447 views
imageCapture2.PNG / V - Attached On 2016-06-30 15:02:00 UTC - Size: 21.76 KB - 303 views
[2016-06-30 18:40:55]
At the time you see the Alert Manager open, select the line in the Alerts Log which was just added and select Edit >> Copy Selection.
Paste it here.
Check all of the Alert Numbers in the General Settings window to make sure none of them are set to send an SMS message. Here are instructions:
https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#AlertSoundSettings
[2016-07-01 12:37:22]
Thank you. I think you solved my problem... I was unaware each alert # had individual settings. A couple of mine had those sms checked boxes ;)
I greatly appreciate it.
M
[2016-07-01 13:10:30]
OK ay this just popped up on message Log window --
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-07-01 08:09:04
Date Time Of Last Edit: 2016-07-01 13:17:27
imageCapture1.PNG / V - Attached On 2016-07-01 13:17:25 UTC - Size: 13.74 KB - 279 views
[2016-07-01 18:56:44]
Refer to the documentation here for instructions about this error:
https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#PeriodicallySetSystemDateTimeFromServer
