Date/Time: Tue, 26 Nov 2024 12:47:09 +0000
indicator for volume vpoc
View Count: 2240
[2016-06-29 19:32:35]
User597594 - Posts: 17
Is there something available in sierra that determines if more volume is transacting above or below vpoc like below fron linnsoft:
Imbalance Factor - Top Left - The number in parenthesis to the right of volume (-18.4 below) is the Imbalance Factor (or ImF). The ImF is computed by taking the difference between the percent of volume above the POC and subtracting the percent of volume below the POC. A value of -18.4 means that 18.4% more volume traded below the POC than above the POC within the given profile. A positive Imbalance Factor reflects a higher percentage of volume trading above the POC than below the POC. The ImF will only show up if there is room to print it. If you're not seeing it, zoom in by using the mouse scroll wheel.
[2016-06-30 20:43:16]
This is supported. We are working on the documentation today and will post it here when ready.
[2016-07-01 05:16:05]
Here is the relevant documentation:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#ViewingVolumeProfileTextInformation
[2016-11-14 00:31:26]
Neo - Posts: 198
Are you going to add new subgraphs to the VbP study so likes of the Volume above POC/ Volume below POC and Ask-Bid Vol Above POC/ Ask-Bid Vol Below POC can easily be extracted using study subgraphs?
[2016-11-14 01:52:17]
There are definitely no plans for this.
Longer term we would have to add functions to ACSIL to obtain these values.
But we are in no position to be doing that now. Allow about one year for this. We will make a note of it.
[2016-11-14 02:19:00]
Neo - Posts: 198
So basically I would need to create a custom study in ACSIL to display these values?
[2016-11-14 17:48:35]
Yes. We can see about adding the Subgraphs to the Volume by Price study, but it does increase memory use.
We do not have any other requests for these. What specific values do you require?
[2016-11-14 18:03:51]
Neo - Posts: 198
Volume Above POC & Volume Below POC would be sufficient.
[2016-11-14 23:41:24]
ganz - Posts: 1048
User597594
SC is amazing to get exactly what you're looking for, I believe.
Check http://www.sierrachart.com/supportboard/showthread.php?t=37616 to start coding with.
[2023-11-29 15:03:39]
Ed C. - Posts: 117
Page no longer exists. :(
[2023-11-29 16:00:37]
Sierra_Chart Engineering - Posts: 17179
We cannot help with this. That page definitely no longer exists.
Date Time Of Last Edit: 2023-11-29 16:00:42
