Date/Time: Tue, 07 Jan 2025 20:55:59 +0000
Problem with IBEX35 and DAX intraday charts
View Count: 717
[2016-06-29 07:26:03] |
Ulaju - Posts: 56 |
Symbols: "IBEX35-201609-MEFFRV" and "DAX-201609-DTB-EUR-25" I'm trying to use continuous futures contract with these symbols to get a 4-5 years intraday charts of range per bar-standard (in ticks). However results are clearly not right. In IBEX35 I get a two-years broken chart. In DAX I get only 6 months of data. Help please? |
[2016-06-29 09:28:18] |
There is no Continuous Futures Contract support for this symbol: "IBEX35-201609-MEFFRV" For the other symbol, first follow the steps here: Interactive Brokers Trading Service: Using Sierra Chart Historical Data After that, follow through the steps here: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-29 16:12:07] |
Ulaju - Posts: 56 |
"DAX-201609-DTB-EUR-25" seems to work well now as long as I don't write any number higher than 1096 in "Days to load" If I write any number higher than 1096 only last contract is loaded... what's the cause of this? |
[2016-06-29 16:27:32] |
That does not make sense. If you have not already done so, follow through the steps here to re-download data for all contract months: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading That should solve the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-29 16:29:53
