Date/Time: Tue, 07 Jan 2025 20:51:04 +0000
Line at Last Bar to Edge
View Count: 639
[2016-06-29 04:18:23] |
User150371 - Posts: 70 |
When applying this Draw Style(eg to the Daily OHLC) I cannot get anything except for a solid line, even when I have the Line Style set at Dash or Dot etc. Do the different Line Styles not work for this ? Thanks.
[2016-06-29 04:26:37] |
This will be solved in the next release.
