Date/Time: Mon, 06 Jan 2025 10:03:11 +0000
Ram requirement for 8 instances
View Count: 699
[2016-06-27 04:49:07] |
User279714 - Posts: 21 |
What is the system configuration required to run 8 instances in parallel with Tradeguider plugin and is it really possible. Regards K.D |
[2016-06-27 05:00:26] |
You can run eight instances of Sierra Chart on your system. We do not know what the memory requirement is because we do not know exactly what you are doing. However, would be a good idea the system has 32 gigabytes of memory. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
