Date/Time: Tue, 07 Jan 2025 20:36:16 +0000
Friday night session data belongs to Saturday
View Count: 843
[2016-06-27 02:07:10] |
User763472 - Posts: 22 |
Dear Sir or Madam, The Friday night session data for HSI future (17:00 to 23:20:00, HK Time also the time zone I use in Sierra)is considered as Saturday data rather than Monday data, making my study "Overnight High/Low" using "High/Low for Time Period-Extended" unable to extend to Pit session on Monday and thus rendering some of my ACSIL studies based upon it failed to work. Do you have any solutions to this? thanks very much! |
[2016-06-27 08:17:09] |
We need to know what the chart Session Times are set to and what the Input settings are for the High/Low for Time Period-Extended study. However, it is not going to be possible to use data from Saturday on the Monday trading day using that study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-27 08:38:25] |
In "Chart Settings" Session Times: Start time: 09:00:00; End Time: 16:15:00; Use Evening Session Evening Start: 17:00:00 Evening End: 23:59:59 High/Low for Time Period-Extended Study: Start Time: 17:00:00 End Time: 23:59:59 |
[2016-06-28 04:50:35] |
These settings are correct but the problem is the High/Low for Time Period study is not going use the data from Saturday for Monday. It can only refer back a single day.
[2016-07-01 03:56:47] |
That was exactly the problem. So every Monday, my chart cannot show the overnight high/low for Friday night session. Do you have an existing solution for this or do I have to use ACSIL to program a customized one? Thanks! |
[2016-07-01 05:33:34] |
No we do not have an existing solution for this.
