Date/Time: Mon, 06 Jan 2025 09:48:48 +0000
Symbols
View Count: 592
[2016-06-24 16:53:24] |
User635149 - Posts: 9 |
Hi, Can you tell me the symbol for the NYSE tick and the NYSE Advanced Decline Line Thank-you, Emily |
[2016-06-24 17:32:40] |
They are documented on this page: Sierra Chart Market Statistics The symbols are TICK-NYSE and NISS-NYSE Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-24 17:32:50
