Date/Time: Mon, 06 Jan 2025 09:18:12 +0000
Volume Filter issue with version 1433
View Count: 717
[2016-06-24 12:35:36] |
NumbersBars - Posts: 141 |
I have just updated to version 1433,and volume filter does not seem to be working normal. When volume filter is set, number bars are emptied/blank even though "Filter Trade completely" is disabled. I have attached the exact same chart/same settings from version 1426 and version 1433 for your reference. |
Private File Private File |
[2016-06-24 17:52:28] |
There are no changes and we would not have expected this. We are testing this now.
[2016-06-24 18:09:54] |
We now know why this happens. It happens for performance reasons. Guess we will have to remove that performance enhancement since this is an unexpected consequence. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-24 19:31:37] |
This is now resolved in version 1434.
