Date/Time: Mon, 06 Jan 2025 10:30:57 +0000
Record has been filtered due to large range while loading Intraday data for DAX.IND.ETR_T1
View Count: 1060
[2016-06-24 11:07:04] |
User837624 - Posts: 17 |
Hi, I have several charts plotting DAX Cash data from Teletrader in different timeframes. One of these charts is not updating itself today (others work OK). Looks like this may be related to one of the indicators attached to this chart - VbP. When the DAX opened today (Sierra was already running) I got and error message. And I get the same error when pressing "Ins" key to reload the chart. Is this a bug or can this be fixed by tweaking settings for VbP? If just one "record was filtered" it would be OK, but I have a chart (and the indicator) that is simply not working today at all... Thank you, Andrei DAX.IND.ETR_T105 5 Min #2 | Reloading chart. | 2016-06-24 07:10:42 TeleTrader | Using primary service for historical data for DAX.IND.ETR_T105 | 2016-06-24 07:10:42 Record has been filtered due to large range while loading Intraday data for DAX.IND.ETR_T105 | 2016-06-24 07:11:25 * DAX.IND.ETR_T105 5 Min #2 | Reloading chart. | 2016-06-24 08:10:36 TeleTrader | Using primary service for historical data for DAX.IND.ETR_T105 | 2016-06-24 08:10:36 Record has been filtered due to large range while loading Intraday data for DAX.IND.ETR_T105 | 2016-06-24 08:11:20 * |
[2016-06-24 11:43:09] |
The solution to this is to increase the Chart >> Chart Settings >> Tick Size setting for the affected charts. Try multiplying it by 2 or 4.
[2016-06-24 12:11:50] |
Thanks! Change from 0.01 to 0.02 did the trick! I still get the same error message in the log, but the chart and VbP both work OK. Thanks again, Andrei |
