Date/Time: Mon, 06 Jan 2025 09:56:19 +0000
Color background techniques
View Count: 635
[2016-06-24 04:45:49] |
Willson - Posts: 176 |
I have indicator in Region 2 that ranges between 0 and -100. Center is -50. Wanting to use transparent backgrounds for 0 to -50 and another color for -51 thru -100. What is good method of ding this? I can do for backgrounds going to panel limits (boundaries), but not to specific numerical limits. Thanks for ideas on this. regards, |
[2016-06-24 04:52:22] |
This can be done by using the Horizontal Lines study. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#FillingArea Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
