Date/Time: Mon, 06 Jan 2025 09:38:43 +0000
VbP Study Issue
View Count: 844
[2016-06-24 00:54:36]
Johnny - Posts: 99
Hello, when I set the transparency level to 100 the point of control is not visible for certain bars. This happens for specific bar spacing levels.
http://www.sierrachart.com/image.php?Image=1466729641237.png
[2016-06-24 00:56:41]
A transparency of 100 percent means the Volume Profiles should not be visible at all.
We cannot help with this. Do not use 100 percent.
[2016-06-24 01:34:29]
Johnny - Posts: 99
A transparency level of 100 hides the volume bars only. The point of control and value area lines are visible unless you set "Extend point of control" and "Extend value area" to none.
[2016-06-24 04:27:30]
The proper way to do what you want is to set the Draw Mode study Input to POC, VAH, VAL Lines Only:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#DrawMode
We are not going to be spending time related to the specific issue you raised. This is likely a lower level graphics issue that we have no control over. Our time is very limited and this is simply not something we would allocate any time too.
Date Time Of Last Edit: 2016-06-24 04:28:17
