Date/Time: Mon, 06 Jan 2025 10:13:47 +0000
Distance between cndles
View Count: 685
[2016-06-23 14:53:31] |
tellerbe - Posts: 109 |
How do I increase the distance between candles? TE |
[2016-06-23 16:53:14] |
Sierra Chart - Max - Posts: 5775 |
To change the bar spacing in a chart use the Up Arrow, Down Arrow, Page Up, and Page Down keys on your keyboard. You can also use the commands on the Chart Menu: https://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#IncreaseSpacing https://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#DecreaseSpacing Or the Control Bar: https://www.sierrachart.com/images/BarSpacingControlBarButtons.png Sierra Chart Support Date Time Of Last Edit: 2016-06-23 16:57:33
[2016-06-23 17:38:56] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChangingBarSpacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
