Date/Time: Mon, 06 Jan 2025 09:17:45 +0000
Only one color for trend
View Count: 1107
[2016-06-23 14:49:13]
User533143 - Posts: 14
hi- is there a way to color bar-only for the trend (pullback bars would hidden)Then bar color would change when trend is reversed. Right now, I have 2 charts up with green bars showing uptrend bars on 1 chart and red bars for downtrend on 2nd chart -with pullback bars hidden on each. Looks better on flex-renko bars; but would like to only look at one chart- Thank You.
[2016-06-23 17:32:47]
For this you need to add 3 Color Bar Based on Alert Condition studies to the chart. The one that you want to use to hide the bars will need to set the bars to the same color as the background color.
Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245
