Date/Time: Mon, 06 Jan 2025 09:49:12 +0000
Historical CBV
View Count: 778
[2016-06-23 14:44:32] |
Greentea - Posts: 26 |
Historical cbv charts are reverting back to none adjusted when exiting then bebooting SC (build 1428)
[2016-06-23 17:41:48] |
That should not happen. We cannot duplicate this. Make sure when you exit Sierra Chart that you are saving the Chartbook and you are opening the same Chartbook. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
