Date/Time: Wed, 08 Jan 2025 17:37:16 +0000
Market Depth Historical Graph and Transact
View Count: 1048
[2016-06-23 08:49:32] |
Outlander - Posts: 91 |
Market Depth Historical Graph has stopped working. Got this massage: Market Depth Historical Graph | Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2016-06-23 04:44:11 * Regards Outlander |
[2016-06-23 17:44:44] |
This will be available soon for TransAct users. TransAct needs to set up the authorization method for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-05 16:27:37] |
Ok,thanks any clue then it will work for Transact users?
[2016-07-05 17:45:08] |
Actually we are not sure as to the timing.
[2016-07-13 09:25:49] |
Any date then Market Depth Historical Graph will work for Transact users?
[2016-07-13 14:18:04] |
No.
