Date/Time: Mon, 06 Jan 2025 09:51:49 +0000
TABS
View Count: 615
[2016-06-23 08:13:57] |
User412599 - Posts: 6 |
Hi Is it possible to install the main chart's TAB on detached chart ? Thank you |
Attachment Deleted. Private File Private File |
[2016-06-23 16:10:59] |
Sierra Chart - Max - Posts: 5775 |
A Detached Chart cannot have chart tabs. But you can Add the Control Bar by enabling Window >> Control Bars >> Control Bar # on the Detached Chart itself. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_WindowMenu.html#ControlBar Sierra Chart Support Date Time Of Last Edit: 2016-06-23 17:34:59
[2016-06-23 17:28:04] |
Thanck you Max.
[2016-06-23 17:35:49] |
If you want to have multiple windows using window tabs requires that you start additional instances of Sierra Chart. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php#UsingDTCServerForDataAndTradingInAnotherSCInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
