Date/Time: Thu, 16 Jan 2025 20:11:31 +0000
Copy drawing tools to charts with different time frames (ACSIL)
View Count: 1854
[2016-06-23 07:46:21] |
User970904 - Posts: 9 |
I have created an indicator with ACSIL that places entry points (arrows using MARKER_POINT) These are placed on the weekly, daily and 30' Is it possible (f.e. using ACSIL) to place these MARKERS from another timeframe to other charts ? Or is it possible to share data generated from the indicator in a chart and use in another chart ? I know there is the possible to copy drawing tools (like trend lines) in the chart settings, but this doesn't seem to work for solitary tools ? ty ! |
[2016-06-23 18:49:12] |
Refer to the documentation here for how to do this: https://www.sierrachart.com/index.php?page=doc/doc_ACSILDrawingTools.html#AddingChartDrawingsToOtherChartsFromACSILStudy Also refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSILRefOtherTimeFrames.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-13 21:49:58] |
User436155 - Posts: 16 |
hello, i would like to add drawings to another chart. i followed first link: #AddingChartDrawingsToOtherChartsFromACSILStudy but i do not want to set s_UseTool::AddAsUserDrawnDrawing to 1 because i do not want user to select those drawings. how can i create drawings on another chart so user can not select/move them? thank you for your help and answer. best regards Jan |
[2017-11-14 01:49:34] |
We have two ideas in regards to this. Just give us a couple of days to get back to you on this.
[2017-11-14 10:18:16] |
wow, that is great news. thank you
[2017-11-14 19:49:09] |
What we have done is we have added a s_UseTool::DrawingLocked member which can be set to 1 to prevent the drawing from being moved. This will be out in the next release. But it still has to be user drawn. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-22 23:38:45] |
it is working as expected. thank you very much ! i have one more question. i tried to find it in documentation but i did not succeded. when drawing objects LineNumber is an integer type. what is the maximum/minimum value of LineNumber? (should be [−32,767, +32,767]). in case that maximum/minimum value is reached does sierra assign correct next index? thank you very much for your answer and have a nice day! Jan |
[2017-11-23 04:36:24] |
You should always let Sierra Chart assign the LineNumber by not setting that member of the s_UseTool structure. The maximum line number is UINT_MAX. Sierra Chart will automatically handle the wrapping when necessary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-23 09:34:43
[2017-11-23 08:56:26] |
do not worry. i do not set the LineNumbers. i was just curious and did not find an answer ;) thank you and have a perfect day! Jan |
[2017-11-24 19:04:28] |
hi there, in study settings i let the user to set a chart number. this chart # is used to copy graphic objects from actual chart. in case there is set a non-existent chart #, graphic objects are placed on the same actual chart. how can i validate/check the existence of chart #? maybe i missed it somehow but i have not found the answer for this issue yet. thank you for the answer and have a nice day Jan |
[2017-11-24 21:28:24] |
We are adding a new ACSIL function for this: sc.IsChartNumberExist(int ChartNumber, const SCString& ChartbookFileName) It will be documented later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-25 18:37:22] |
thank you very much.
[2017-11-26 00:10:11] |
Do not say thank you.
