Date/Time: Mon, 06 Jan 2025 10:05:53 +0000
Write Bar Data to File
View Count: 1314
[2016-06-23 00:39:10] |
User713273 - Posts: 409 |
Hi - Im using the 1 minute chart currently. Is it not possible to extract data on a 1 second timeframe using the 1 minute chart? Meaning for every 1 minute bar that is built, 60 data points would be extracted into a filename. Also could these data point be extracted using studies uploaded to said chart? Thx http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s182 Date Time Of Last Edit: 2016-06-23 00:47:24
[2016-06-23 00:48:56] |
You need to change the chart bars to 1 second per bar to do what you want. Did you want to export the study data as well? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-23 00:52:13] |
Yes, using Study Angle based on Moving Average. You need to change the chart bars to 1 second per bar to do what you want.
Would this not affect the parameters Im using on the 1 minute chart since this is the chart I have based my parameters on? And also have values inputted for the 1 minute chart. Date Time Of Last Edit: 2016-06-23 00:53:29
[2016-06-24 01:00:57] |
Yes of course, but you have to set the chart bars to the timeframe of the data that you want to export.You can export price and study data using Edit >>Export Bar and Study Data to Text File. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-24 01:01:38
