Date/Time: Mon, 06 Jan 2025 09:19:23 +0000
SC Historical Data Feed question
View Count: 622
[2016-06-22 23:33:02]
onnb - Posts: 662
Using SC Historical Data Feed, I am currently able to see intraday data going back to 2013-09-27
I am viewing stock for example looking at AAPL
1. How much data should I be able to see? Was expecting to see 36 months so was expecting to see till 2013-06-22
2. Is there a way to get more intraday data. Does not have to be tick level. Could be minute level data. Is it a matter of package? Would using the SC Exchange Data feed help?
[2016-06-23 05:53:34]
1, 2. There is data back to 2008. Refer to:
http://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData
[2016-06-23 17:48:02]
onnb - Posts: 662
Works - I can see data back to 2008.
Is 2008 the beginning of the data you have available or do you limit to 8 years? For example, if I downloaded in 2017, would I still get data going back to 2008 or would it download only back to 2009?
[2016-06-23 17:53:21]
That is the beginning of the available data. So it will always start at that time.
