Date/Time: Thu, 09 Jan 2025 19:42:05 +0000
Different stop limit offset on primary and attached order in ACSIL ?
View Count: 872
[2016-06-22 22:24:57] |
wwwingman - Posts: 185 |
Hi The s_SCNewOrder::StopLimitOrderLimitOffset sets the primary AND attached orders stop limits orders to the same offset. Is it possible to have a different stop limit offset for the primary and attached orders ? (it is possible in the dom settings but I don't see on ACSIL how to do that). For ex: // set entry target and stop
_order.Price1 = ... _order.OrderType = SCT_ORDERTYPE_STOP_LIMIT; _order.OrderQuantity = ... _order.Target1Offset = ... _order.AttachedOrderTarget1Type = SCT_ORDERTYPE_LIMIT; _order.Stop1Price = ... _order.AttachedOrderStop1Type = SCT_ORDERTYPE_STOP_LIMIT; // set the stop limits offset _order.StopLimitOrderLimitOffset = ... // PROBLEM : sets entry and stop to the same stop limit offset ... Please advise.. -- W |
[2016-06-23 18:56:42] |
Support for this will need to be added. We will do that.
[2016-08-11 00:03:37] |
We are working on this now.
