Date/Time: Mon, 06 Jan 2025 10:29:22 +0000
DATA folder
View Count: 664
[2016-06-22 21:00:38] |
jivetrader - Posts: 410 |
please consider changing your directory structure. it is impossible to make windows backups of my chartbooks in the data folder because all the .scid files are comingled with them. these items should not be in the same folder. please consider changing this.
[2016-06-23 01:20:23] |
You can write a commandline batch file which copies the Chartbooks to another folder and then you can back them up from there.
