Date/Time: Mon, 06 Jan 2025 10:16:31 +0000
X_Trader API
View Count: 739
[2016-06-22 08:37:50] |
Futurestrader77 - Posts: 126 |
Dear Support Team, is it possible to connect Sierra Chart via the X_Trader API (instead of the TT Fix)? Thank you! |
[2016-06-22 09:31:21] |
Only TT FIX is supported for TT connections. We would never use the X-trader API. Our policy is firmly stated here: Https://www.sierrachart.com/index.php?l=helpdetails76.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
